주요 콘텐츠로 건너뛰기
Beats Studio 2.0 Wireless Left Interior Side Panel Replacement
필요한 것
  1. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement, Left Interior Side Panel: 1 단계, 이미지 1/1
    • Use metal spudger to pry away ear cushion.
  2. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 2 단계, 이미지 1/1
    • Remove ear cushion from headphones (attached by adhesive).
  3. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 3 단계, 이미지 1/1
    • Remove two screws from the metal hinge using a Phillips head screwdriver to allow more motion from the speaker housing and more accessibility.
  4. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 4 단계, 이미지 1/1
    • Remove five screws using a Phillips head screwdriver from speaker housing.
  5. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 5 단계, 이미지 1/1
    • Pull speaker away to access second secondary housing.
    • Be careful not to stress wires and break solder points.
  6. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 6 단계, 이미지 1/2 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 6 단계, 이미지 2/2
    • Raise center cover.
    • Remove screw from center of housing.
  7. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 7 단계, 이미지 1/1
    • Pull secondary housing away gently being careful not to damage the wires.
  8. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 8 단계, 이미지 1/1
    • Remove four screws using a Phillips head screwdriver to remove the third housing.
  9. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 9 단계, 이미지 1/3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 9 단계, 이미지 2/3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 9 단계, 이미지 3/3
    • Disconnect wires gently.
    • Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages.
  10. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 10 단계, 이미지 1/3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 10 단계, 이미지 2/3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 10 단계, 이미지 3/3
    • Pass wire through new housing and reconnect wires.
  11. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: 11 단계, 이미지 1/1
    • Snap housing into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Antares Cam
회원 가입일: 02/27/18
235 평판
안내서 1개 작성함
colby and cameron colby and cameron 회원
Community
2 회원들
안내서 1개 작성하였습니다
댓글 2개
Thank you for your tutorial!
Jonathan Concepcion - 답글
appreciate it, fixed both side panels on my beats
mridha31 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 24
전체 시간: 5,603
