주요 콘텐츠로 건너뛰기
Beats Studio First Generation Ear Cushion Replacement
필요한 것
  1. Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: 1 단계, 이미지 1/3 Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: 1 단계, 이미지 2/3 Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: 1 단계, 이미지 3/3
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
    i have torn my cuson inside part that helps to hold the out soft part. and i lost it how to do it
    imbd Indian medicine bd - 답글
  2. Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: 2 단계, 이미지 1/3 Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: 2 단계, 이미지 2/3 Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: 2 단계, 이미지 3/3
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
    Hi does this work for the beats studio wireless?
    Jack - 답글
    I bought the parts two (2) ear cushions and a head band replacement on eBay for about $10 USD
    the process described here works well if the ear pad is old and you do not mind destroying the old one to gain access - however you will destroy the ear cushion pad assembly to separate it from the headphones - so be prepared to buy replacement cushion assemblies - when you disassemble you cannot re-install the original cushions
    the disassembly process tears the plastic cover that goes around the ear cushion plastic ring
    Legacy Finance Group - 답글
결승점
다른 15명이 해당 안내서를 완성하였습니다.
Anand Mangal
회원 가입일: 04/15/14
1,064 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 회원
CPSU-REGAN-S14S9G18
4 회원들
안내서 11개 작성하였습니다
댓글 4개
De nada me sirve saber cómo colocarlos si no sé donde conseguirlos... Ese debería ser el paso 1 del instructivo...
IGNACIO GREIFFENSTEIN - 답글
What if I break the black ring where do I get a replacement
Chris h - 답글
Hi - do you know where i can buy the replacement ear cushions for these particular headphones?
Jade ijeh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 99
전체 시간: 62,545
