주요 콘텐츠로 건너뛰기
Beats Studio First Generation Headband Replacement
필요한 것
  1. Beats Studio First Generation Headband Replacement, Removing the outer headband screws.: 1 단계, 이미지 1/1
    • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
    • 4 (2 per side) Torx type T5, 3.5mm long screws.
    not necessary !!
    John Coops - 답글
  2. Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 2 단계, 이미지 1/2 Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 2 단계, 이미지 2/2
    • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
    not necessary !!
    John Coops - 답글
    where can i find this piece?
    alex - 답글
  3. Beats Studio First Generation Headband Replacement, Removing the hinge pins.: 3 단계, 이미지 1/1
    • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
    • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
    i need to buy one hinge pin for my beats by dre 1.0 studio
    mrfuentescisneros - 답글
    This is DEFINITELY NOT necessary !
    John Coops - 답글
  4. Beats Studio First Generation Headband Replacement, Removing the metal bands.: 4 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
    • 4 (2 per side) Torx type T5, 4.0mm long screws.
    This step is DEFINITELY NOT necessary !
    John Coops - 답글
  5. Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 5 단계, 이미지 1/3 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 5 단계, 이미지 2/3 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 5 단계, 이미지 3/3
    • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
    John Coops - 답글
  6. Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 6 단계, 이미지 1/2 Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 6 단계, 이미지 2/2
    • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
    • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
    • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
    John Coops - 답글
결론
다른 20명이 해당 안내서를 완성하였습니다.
Anand Mangal
회원 가입일: 04/15/14
1,064 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 회원
CPSU-REGAN-S14S9G18
4 회원들
안내서 11개 작성하였습니다
댓글 2개
where can i buy the pin for the hinge i woud like you know email the link to this email drkimaging@gmail.com
derek - 답글
When replacing the headband there is no need to remove any screws or hinges for the beats studio 1.0 as described here.
Simply carefully remove the headband cushion by snapping it out from the frame as it is merely a push fir and not reattained at the two ends it is just push fit into the top plastic section. Just tease it out gently with small screwdriver and then the the replacement in place and listen to the click as it snaps in. Simple and easy takes less than a minute.
Roger Holland - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 132
전체 시간: 79,718
