주요 콘텐츠로 건너뛰기
Beats Studio3 Micro USB-B Replacement
필요한 것
  1. Beats Studio3 Micro USB-B Replacement, Micro USB-B: 1 단계, 이미지 1/3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: 1 단계, 이미지 2/3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: 1 단계, 이미지 3/3
    • Remove the pad that is on the charging port side using an opening tool.
  2. Beats Studio3 Micro USB-B Replacement: 2 단계, 이미지 1/3 Beats Studio3 Micro USB-B Replacement: 2 단계, 이미지 2/3 Beats Studio3 Micro USB-B Replacement: 2 단계, 이미지 3/3
    • Remove seven screws from the earpiece using a Phillips screwdriver.
    • Pry the top panel away from the rest of the speaker using an opening tool.
    • There will still be wires attached, so be gentle.
  3. Beats Studio3 Micro USB-B Replacement: 3 단계, 이미지 1/3 Beats Studio3 Micro USB-B Replacement: 3 단계, 이미지 2/3 Beats Studio3 Micro USB-B Replacement: 3 단계, 이미지 3/3
    • Use the soldering iron to carefully desolder five different wires from their respective points.
    • After disconnecting the wires, gently push the charger upward using your fingers to detach it from the base. Be careful to avoid damaging any components
    • Position the new charger by aligning it properly with the base. Push the new charger into place, ensuring it fits snugly and securely.
    • Reattach the five wires to their designated points on the new charger by soldering them securely. Ensure each wire is correctly connected to its corresponding point to guarantee proper functionality.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jael Estrada-Cervantes
회원 가입일: 11/03/23
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-7, Kershman Fall 2023 CSU Los Angeles, Team 4-7, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 32
30일 전: 85
전체 시간: 345
