주요 콘텐츠로 건너뛰기
Beats Studio3 Wireless Battery Replacement
필요한 것
  1. Beats Studio3 Wireless Battery Replacement, Battery: 1 단계, 이미지 1/2 Beats Studio3 Wireless Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
  2. Beats Studio3 Wireless Battery Replacement: 2 단계, 이미지 1/2 Beats Studio3 Wireless Battery Replacement: 2 단계, 이미지 2/2
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
  3. Beats Studio3 Wireless Battery Replacement: 3 단계, 이미지 1/3 Beats Studio3 Wireless Battery Replacement: 3 단계, 이미지 2/3 Beats Studio3 Wireless Battery Replacement: 3 단계, 이미지 3/3
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
  4. Beats Studio3 Wireless Battery Replacement: 4 단계, 이미지 1/1
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Beats Studio3 Wireless Battery Replacement: 5 단계, 이미지 1/2 Beats Studio3 Wireless Battery Replacement: 5 단계, 이미지 2/2
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Lourdes Dejesus
회원 가입일: 03/16/23
213 평판
안내서 1개 작성함
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G4
3 회원들
안내서 5개 작성하였습니다
댓글 3개
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - 답글
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb -
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 77
30일 전: 352
전체 시간: 4,471
