주요 콘텐츠로 건너뛰기
Beboncool Gamepad for Nintendo Switch Charging Port Replacement
필요한 것
  1. Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 2 단계, 이미지 1/2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 3 단계, 이미지 1/3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 3 단계, 이미지 2/3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 3 단계, 이미지 3/3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 4 단계, 이미지 1/2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 5 단계, 이미지 1/2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 5 단계, 이미지 2/2
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 6 단계, 이미지 1/2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 6 단계, 이미지 2/2
    • Gently pull the battery from the circuit board, leaving it connected to the board with its lead wires.
  7. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 7 단계, 이미지 1/3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 7 단계, 이미지 2/3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 7 단계, 이미지 3/3
    • Remove the charging port from the edge of the motherboard by desoldering each of its four solder points and lifting the port from the board.
결론
Riley McCullough
회원 가입일: 01/30/20
285 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 18
전체 시간: 666
