주요 콘텐츠로 건너뛰기
Beboncool Wireless Switch Pro Controller Buttons Replacement
필요한 것
  1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
  2. Beboncool Wireless Switch Pro Controller Buttons Replacement: 2 단계, 이미지 2개 중 1개 Beboncool Wireless Switch Pro Controller Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Gently separate the top and bottom halves of the controller.
  3. Beboncool Wireless Switch Pro Controller Buttons Replacement: 3 단계, 이미지 2개 중 1개 Beboncool Wireless Switch Pro Controller Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws holding the joystick motherboard in place.
  4. Beboncool Wireless Switch Pro Controller Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully move the bumper buttons out of the way.
  5. Beboncool Wireless Switch Pro Controller Buttons Replacement: 5 단계, 이미지 2개 중 1개 Beboncool Wireless Switch Pro Controller Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the 5 mm screw holding the motherboard in place.
    • Remove the motherboard.
  6. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: 6 단계, 이미지 2개 중 1개 Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • To remove the alphabetic buttons, remove the translucent silicone cover.
    • Use tweezers or your fingers to remove the buttons.
    • Pushing a button from below will elevate them enough to easily grab them.
  7. Beboncool Wireless Switch Pro Controller Buttons Replacement: 7 단계, 이미지 2개 중 1개 Beboncool Wireless Switch Pro Controller Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • To remove the directional buttons, first remove the translucent silicone cover. Then, use tweezers or your fingers to remove the button pad.
    • As with the alphabetic buttons, push on the buttons from below, then grab them.
결론
작성자
3다른 기여자 명과 함께
Tayah Appel
회원 가입일: 03/27/23
529 평판
안내서 5개를 작성함
Casper College, Team 1-3, Lareau Spring 2023 Casper College, Team 1-3, Lareau Spring 2023 회원
CASC-LAREAU-S23S1G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 195
