주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bed Head Wave Artist Deep Waver Power Cord Replacement
필요한 것
  1. Bed Head Wave Artist Deep Waver Power Cord Replacement, Lower Handle Housing: 1 단계, 이미지 2개 중 1개 Bed Head Wave Artist Deep Waver Power Cord Replacement, Lower Handle Housing: 1 단계, 이미지 2개 중 2개
    • Before disassembling your Deep Waver, be sure to unplug the device to avoid electric shock, and make sure the heating elements of the device are cool to avoid burns.
    • Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
    • Remove two 10 mm Phillips #01 screws from the lower handle housing.
    • Remove one 10 mm Phillips #02 screw from the lower handle housing.
  2. Bed Head Wave Artist Deep Waver Power Cord Replacement: 2 단계, 이미지 1개 중 1개
    • Pry the black screw cover off the side of the lower handle housing using a fine-point spudger or pick. This side will have the model number and other product information embossed on it.
  3. Bed Head Wave Artist Deep Waver Power Cord Replacement: 3 단계, 이미지 1개 중 1개
    • Remove one 10 mm Phillips 1 screw from the handle joint.
  4. Bed Head Wave Artist Deep Waver Power Cord Replacement: 4 단계, 이미지 1개 중 1개
    • Pry the black screw cover off the other side of the lower handle housing. This side will have the power switch located on it.
  5. Bed Head Wave Artist Deep Waver Power Cord Replacement: 5 단계, 이미지 1개 중 1개
    • Cut along the length of the black housing retainer with a rotary tool to split and remove the retainer.
  6. Bed Head Wave Artist Deep Waver Power Cord Replacement: 6 단계, 이미지 1개 중 1개
    • Split the lower handle housing apart using a plastic opening tool.
    • Begin splitting the housing at one end rather than the center to avoid cracking the casing.
  7. Bed Head Wave Artist Deep Waver Power Cord Replacement, Power Cord: 7 단계, 이미지 1개 중 1개
    • Pull upward on the power cord connector to remove it from the lower handle housing.
  8. Bed Head Wave Artist Deep Waver Power Cord Replacement: 8 단계, 이미지 1개 중 1개
    • Gently pull the power cord out of the power lead connector.
결론
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
작성자
1다른 기여자 명과 함께
Grant Peters
회원 가입일: 11/06/17
401 평판
안내서 4개를 작성함
IUPUI, Team S6-G3, Baechle Fall 2017 IUPUI, Team S6-G3, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S6G3
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 27
전체 시간: 759
