소개
The control PCB is attached to the inside of the back panel, and provides access to adjustment knobs and inputs and outputs for the B212D speaker.
필요한 것
Remove the 8 Phillips screws from the back of the speaker.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Remove the 4 indicated 9/32" long screws with the #1 phillips head screwdriver
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
In Step 3 there are 2 more screws, along the side of the 'electronics box’.
The washer and nut securing the 1/4” socket also need to be removed.
Hi,i like to conect the board to another amp pcb but i dont now wich cable is for what ,do you now where is the power and the inputs?i already look for schematics but i didnt find anything about..thanx
Where do I find a replacement control PCB for my B212A??
Hi
My Behringer Eurolive B215D speaker has got a serious hissing sound when I plug just the power with no audio player connected. Anyone with any idea what can course this? Thanks.
Eurolive B212d back plate requirement
Ashok Ahlawat - 답글
