주요 콘텐츠로 건너뛰기
Beiens Cartoon RC Race Car Car Battery Replacement
필요한 것
  1. Beiens Cartoon RC Race Car Car Battery Replacement, Car Battery: 1 단계, 이미지 1/1
    • On the bottom of the car, unscrew the 6.2 mm screw that houses the batteries using a Philips 00 precision screwdriver.
  2. Beiens Cartoon RC Race Car Car Battery Replacement: 2 단계, 이미지 1/1
    • Pull up the tab to reveal the battery compartment.
  3. Beiens Cartoon RC Race Car Car Battery Replacement: 3 단계, 이미지 1/1
    • Insert AA batteries into the 3 spaces with the flat end of the battery facing the metal spring.
    • Be sure to insert the batteries with the positive and negative ends facing the right direction. The flat negative end of the battery should be in contact with the spring in the remote control car.
결론
This guide was made to work for the Beiens Cartoon RC Race Car with AA batteries, but it should also work with other similar modeled RC cars that take AA batteries.
Amber Ashley
회원 가입일: 10/01/15
329 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-6, Leahy Fall 2015 USF Tampa, Team 1-6, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 584
