주요 콘텐츠로 건너뛰기
Belkin NetCam HD Circuit Board Replacement
필요한 것
  1. Belkin NetCam HD Circuit Board Replacement, Case: 1 단계, 이미지 1개 중 1개
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Circuit Board Replacement, Microphone: 4 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement, Microphone: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Circuit Board Replacement: 5 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
  6. Belkin NetCam HD Circuit Board Replacement, Speaker: 6 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement, Speaker: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  7. Belkin NetCam HD Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Belkin NetCam HD Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Belkin NetCam HD Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  8. Belkin NetCam HD Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull the speaker out of the holder from the back of the cover.
  9. Belkin NetCam HD Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
  10. Belkin NetCam HD Circuit Board Replacement, Lens Piece: 10 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement, Lens Piece: 10 단계, 이미지 2개 중 2개
    • Flip the circuit board to the back side.
    • Fold down the tape with your finger.
    • With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
  11. Belkin NetCam HD Circuit Board Replacement: 11 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement: 11 단계, 이미지 2개 중 2개
    • Flip the circuit board back to the other side.
    • Unscrew the screw with a Phillips #0 screw driver.
  12. Belkin NetCam HD Circuit Board Replacement: 12 단계, 이미지 1개 중 1개
    • Slide the attached piece from the lens holder device.
  13. Belkin NetCam HD Circuit Board Replacement: 13 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to pull the white attachment out from the port a little.
    • Then, take your fingers and gently pull the white attachment out from the tan port.
  14. Belkin NetCam HD Circuit Board Replacement, Switch Cover: 14 단계, 이미지 2개 중 1개 Belkin NetCam HD Circuit Board Replacement, Switch Cover: 14 단계, 이미지 2개 중 2개
    • On the back of the board pull the switch slowly upward to take it off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Destinie DiazVerdejo
회원 가입일: 10/04/16
805 평판
안내서 7개를 작성함
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G5
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 12
전체 시간: 728
