주요 콘텐츠로 건너뛰기
Belkin NetCam HD Switch Cover Replacement
필요한 것
  1. Belkin NetCam HD Switch Cover Replacement, Case: 1 단계, 이미지 1/1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Switch Cover Replacement: 2 단계, 이미지 1/1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Switch Cover Replacement: 3 단계, 이미지 1/2 Belkin NetCam HD Switch Cover Replacement: 3 단계, 이미지 2/2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Switch Cover Replacement, Front Casing: 4 단계, 이미지 1/1
    • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
  5. Belkin NetCam HD Switch Cover Replacement, Speaker: 5 단계, 이미지 1/2 Belkin NetCam HD Switch Cover Replacement, Speaker: 5 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  6. Belkin NetCam HD Switch Cover Replacement: 6 단계, 이미지 1/3 Belkin NetCam HD Switch Cover Replacement: 6 단계, 이미지 2/3 Belkin NetCam HD Switch Cover Replacement: 6 단계, 이미지 3/3
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  7. Belkin NetCam HD Switch Cover Replacement: 7 단계, 이미지 1/2 Belkin NetCam HD Switch Cover Replacement: 7 단계, 이미지 2/2
    • Gently pull the speaker out of the holder from the back of the cover.
  8. Belkin NetCam HD Switch Cover Replacement: 8 단계, 이미지 1/1
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
  9. Belkin NetCam HD Switch Cover Replacement, Switch Cover: 9 단계, 이미지 1/2 Belkin NetCam HD Switch Cover Replacement, Switch Cover: 9 단계, 이미지 2/2
    • On the back of the board pull the switch slowly upward to take it off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Destinie DiazVerdejo
회원 가입일: 10/04/16
805 평판
안내서 7개 작성하였습니다
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 218
