주요 콘텐츠로 건너뛰기
Bell and Howell DNV16HDZ Front Lens Replacement
필요한 것
  1. Bell and Howell DNV16HDZ Front Lens Replacement, Lens Assembly: 1 단계, 이미지 1/2 Bell and Howell DNV16HDZ Front Lens Replacement, Lens Assembly: 1 단계, 이미지 2/2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Front Lens Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Front Lens Replacement: 3 단계, 이미지 1/1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Front Lens Replacement, Front Lens: 4 단계, 이미지 1/1
    • Take out the two 20 mm screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ Front Lens Replacement: 5 단계, 이미지 1/1
    • Remove the ten 30 mm Phillips #0 screws from the front lens.
  6. Bell and Howell DNV16HDZ Front Lens Replacement: 6 단계, 이미지 1/1
    • Take the shutter screen parts out of the lens.
    • Now push out the front lens.
    • Slowly take out the shutter screen parts and lens, adding too much force will break them.
결론
Jerry Hadjah
회원 가입일: 03/04/16
525 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 583
