주요 콘텐츠로 건너뛰기
Bell and Howell DNV16HDZ Hand Strap Replacement
필요한 것
  1. Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: 1 단계, 이미지 1/2 Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: 1 단계, 이미지 2/2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Hand Strap Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Hand Strap Replacement: 3 단계, 이미지 1/1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: 4 단계, 이미지 1/2 Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: 4 단계, 이미지 2/2
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
    • Unscrew the four 40 mm Phillips #0 screws.
    • Add the new hand strap now.
결론
Jerry Hadjah
회원 가입일: 03/04/16
525 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 222
