주요 콘텐츠로 건너뛰기
Bell and Howell DNV16HDZ Internal Screen Replacement
필요한 것
  1. Bell and Howell DNV16HDZ Internal Screen Replacement, Lens Assembly: 1 단계, 이미지 2개 중 1개 Bell and Howell DNV16HDZ Internal Screen Replacement, Lens Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Internal Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Internal Screen Replacement: 3 단계, 이미지 1개 중 1개
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Internal Screen Replacement, Internal Screen: 4 단계, 이미지 1개 중 1개
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
  5. Bell and Howell DNV16HDZ Internal Screen Replacement: 5 단계, 이미지 2개 중 1개 Bell and Howell DNV16HDZ Internal Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery.
    • Remove the four 30 mm Phillips #0 screws on the back.
  6. Bell and Howell DNV16HDZ Internal Screen Replacement: 6 단계, 이미지 3개 중 1개 Bell and Howell DNV16HDZ Internal Screen Replacement: 6 단계, 이미지 3개 중 2개 Bell and Howell DNV16HDZ Internal Screen Replacement: 6 단계, 이미지 3개 중 3개
    • On the hinge of the camcorder remove the two 30 mm Phillips #0 screws.
    • Remove blue piece holding it together.
    • Remove the 50 mm Phillips #0 screw.
  7. Bell and Howell DNV16HDZ Internal Screen Replacement: 7 단계, 이미지 2개 중 1개 Bell and Howell DNV16HDZ Internal Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use the plastic opening tool and slowly pry open the side.
    • Now pull the part with camcorder out.
    • There is a wire connecting these two pieces using to much force will damage the camcorder.
  8. Bell and Howell DNV16HDZ Internal Screen Replacement: 8 단계, 이미지 3개 중 1개 Bell and Howell DNV16HDZ Internal Screen Replacement: 8 단계, 이미지 3개 중 2개 Bell and Howell DNV16HDZ Internal Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Have the screen open and twist it 90 degrees unscrew the 40 mm screw.
    • Repeat for the other side.
    • Use the plastic opening tool to pry the outer part of the screen, now attach the new one.
결론
작성자
2다른 기여자 명과 함께
Jerry Hadjah
회원 가입일: 03/04/16
525 평판
안내서 5개를 작성함
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 513
