주요 콘텐츠로 건너뛰기
Bell and Howell DNV16HDZ LED Replacement
필요한 것
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: 1 단계, 이미지 2개 중 1개 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: 3 단계, 이미지 1개 중 1개
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: 4 단계, 이미지 1개 중 1개
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: 5 단계, 이미지 3개 중 1개 Bell and Howell DNV16HDZ LED Replacement: 5 단계, 이미지 3개 중 2개 Bell and Howell DNV16HDZ LED Replacement: 5 단계, 이미지 3개 중 3개
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
결론
작성자
3다른 기여자 명과 함께
Donald Desrosier
회원 가입일: 03/11/16
101 평판
안내서 1개를 작성함
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 429
