주요 콘텐츠로 건너뛰기
Bella 4-Slice Toaster Oven Heating Element Replacement
필요한 것
  1. Bella 4-Slice Toaster Oven Heating Element Replacement, Outer Shell: 1 단계, 이미지 1/1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Heating Element Replacement: 2 단계, 이미지 1/1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Heating Element Replacement: 3 단계, 이미지 1/1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Heating Element Replacement: 4 단계, 이미지 1/1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Heating Element Replacement: 5 단계, 이미지 1/1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Heating Element Replacement: 6 단계, 이미지 1/1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Heating Element Replacement: 7 단계, 이미지 1/1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Heating Element Replacement: 8 단계, 이미지 1/1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Heating Element Replacement, Heating Element: 9 단계, 이미지 1/1
    • Remove the red wire from the heating element.
  10. Bella 4-Slice Toaster Oven Heating Element Replacement: 10 단계, 이미지 1/1
    • Remove white wire from the opposite side of the heating element.
  11. Bella 4-Slice Toaster Oven Heating Element Replacement: 11 단계, 이미지 1/1
    • Use a metal spudger to unfold the tabs of metal that hold heating element in place.
  12. Bella 4-Slice Toaster Oven Heating Element Replacement: 12 단계, 이미지 1/3 Bella 4-Slice Toaster Oven Heating Element Replacement: 12 단계, 이미지 2/3 Bella 4-Slice Toaster Oven Heating Element Replacement: 12 단계, 이미지 3/3
    • Gently push the heating element from the side with the red wire to remove it from the toaster.
  13. Bella 4-Slice Toaster Oven Heating Element Replacement: 13 단계, 이미지 1/1
    • Repeat steps 1-4 for the second heating element.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Pierce Hampton
회원 가입일: 01/31/19
561 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 51
전체 시간: 1,910
