주요 콘텐츠로 건너뛰기
Bella 4-Slice Toaster Oven Outer Shell Replacement
필요한 것
  1. Bella 4-Slice Toaster Oven Outer Shell Replacement, Outer Shell: 1 단계, 이미지 1/1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Outer Shell Replacement: 2 단계, 이미지 1/1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Outer Shell Replacement: 3 단계, 이미지 1/1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Outer Shell Replacement: 4 단계, 이미지 1/1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Outer Shell Replacement: 5 단계, 이미지 1/1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Outer Shell Replacement: 6 단계, 이미지 1/1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Outer Shell Replacement: 7 단계, 이미지 1/1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Outer Shell Replacement: 8 단계, 이미지 1/1
    • Lift the black outer cover off of the toaster
결론
Pierce Hampton
회원 가입일: 01/31/19
561 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 8
전체 시간: 386
