주요 콘텐츠로 건너뛰기
Belling Synergie Oven Technique
  1. Belling Synergie Oven Technique, Belling Synergie Oven Technique: 1 단계, 이미지 1/1
    • Hold down either the first or first two buttons (depending on the model).
    • Use the arrow buttons to set the clock (It always starts at 12:00).
결론
다른 6명이 해당 안내서를 완성하였습니다.
Peter Neal
회원 가입일: 02/06/11
186 평판
안내서 1개 작성함
댓글 3개
What if the buttons stopped working? I can’t press them down.
Elizabeth Robertson - 답글
Update:
I can press them down like I normally can but the clock won’t change and the time stays as it is. I can only use the top oven.
Something that worked with my Blomberg and may help is to turn off the power to the oven, wait 10 seconds and then turn the power back on - the oven then behaves as though it is being newly installed, the clock resets to 12.00, and should be re-settable. Good luck
Howard Morgan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 107
전체 시간: 18,856
