주요 콘텐츠로 건너뛰기
Bem Wireless HL2739B Speaker Motherboard Replacement
필요한 것
  1. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Battery: 1 단계, 이미지 1/1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B  Speaker Motherboard Replacement: 2 단계, 이미지 1/3 Bem Wireless HL2739B  Speaker Motherboard Replacement: 2 단계, 이미지 2/3 Bem Wireless HL2739B  Speaker Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B  Speaker Motherboard Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B  Speaker Motherboard Replacement: 4 단계, 이미지 1/1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B  Speaker Motherboard Replacement: 5 단계, 이미지 1/1
    • Using tweezers, pull the wires from the metal base connection.
  6. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: 6 단계, 이미지 1/2 Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: 6 단계, 이미지 2/2
    • Unscrew the four 10mm screws from the motherboard.
  7. Bem Wireless HL2739B  Speaker Motherboard Replacement: 7 단계, 이미지 1/2 Bem Wireless HL2739B  Speaker Motherboard Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the blue/white and red/black wires from motherboard.
  8. Bem Wireless HL2739B  Speaker Motherboard Replacement: 8 단계, 이미지 1/2 Bem Wireless HL2739B  Speaker Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently re-position the motherboard so you can access the bus wire connected to the speaker.
    • Remove bus wire from the speaker and lift out the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ryan McQueeney
회원 가입일: 02/28/17
446 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G4, Nance Spring 2017 USF Tampa, Team S2-G4, Nance Spring 2017 회원
USFT-NANCE-S17S2G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 920
