주요 콘텐츠로 건너뛰기
Bem Wireless HL2739B Charging base motherboard Replacement
필요한 것
  1. Bem Wireless HL2739B Charging base motherboard Replacement, Charging Base Battery: 1 단계, 이미지 1개 중 1개
    • Peel the rubber cover back from the corner of the auxiliary charging base to reveal the screw.
  2. Bem Wireless HL2739B Charging base motherboard Replacement: 2 단계, 이미지 2개 중 1개 Bem Wireless HL2739B Charging base motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the auxiliary charging base.
  3. Bem Wireless HL2739B Charging base motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the bottom cover away from the rest of the auxiliary charging base.
    • There are wires connecting the battery and cover to the rest of the auxiliary charging base. Be careful when removing the auxiliary charging base cover.
  4. Bem Wireless HL2739B Charging base motherboard Replacement: 4 단계, 이미지 2개 중 1개 Bem Wireless HL2739B Charging base motherboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers, pull the wires from the auxiliary charging base's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the auxiliary charging base after this step.
  5. Bem Wireless HL2739B Charging base motherboard Replacement, Charging Base Motherboard: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the black wire from the motherboard
  6. Bem Wireless HL2739B Charging base motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, gently pry the motherboard up and remove it from the charging base.
    • There are no screws to be removed from the motherboard.
결론
작성자
3다른 기여자 명과 함께
Ryan McQueeney
회원 가입일: 02/28/17
446 평판
안내서 4개를 작성함
USF Tampa, Team S2-G4, Nance Spring 2017 USF Tampa, Team S2-G4, Nance Spring 2017 회원
USFT-NANCE-S17S2G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 651
