주요 콘텐츠로 건너뛰기
BenQ HT1075 Projector Blower Fan Replacement
필요한 것
  1. BenQ HT1075 Projector Blower Fan Replacement, Lamp: 1 단계, 이미지 1/1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Blower Fan Replacement: 2 단계, 이미지 1/1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Blower Fan Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Blower Fan Replacement: 4 단계, 이미지 1/1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Blower Fan Replacement, Circuit Board: 5 단계, 이미지 1/1
    • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
  6. BenQ HT1075 Projector Blower Fan Replacement, Remove the 6th screw holding the top cover: 6 단계, 이미지 1/1
    • Flip the projector and remove the 6th and last crew.
  7. BenQ HT1075 Projector Blower Fan Replacement: 7 단계, 이미지 1/1
    • Using an opening tool, remove the top cover by first loosening its top cover.
  8. BenQ HT1075 Projector Blower Fan Replacement: 8 단계, 이미지 1/2 BenQ HT1075 Projector Blower Fan Replacement: 8 단계, 이미지 2/2
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform.
    • Gently pull the top cover from the rest of the frame.
  9. BenQ HT1075 Projector Blower Fan Replacement: 9 단계, 이미지 1/2 BenQ HT1075 Projector Blower Fan Replacement: 9 단계, 이미지 2/2
    • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
    • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
  10. BenQ HT1075 Projector Blower Fan Replacement: 10 단계, 이미지 1/3 BenQ HT1075 Projector Blower Fan Replacement: 10 단계, 이미지 2/3 BenQ HT1075 Projector Blower Fan Replacement: 10 단계, 이미지 3/3
    • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
    • Afterwards, use a 5mm nut driver to remove the four remaining screws.
    • Use the opening tool to loosen the back cover then pull it off.
  11. BenQ HT1075 Projector Blower Fan Replacement: 11 단계, 이미지 1/1
    • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
    • Remove the metal casing.
  12. BenQ HT1075 Projector Blower Fan Replacement: 12 단계, 이미지 1/2 BenQ HT1075 Projector Blower Fan Replacement: 12 단계, 이미지 2/2
    • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
    • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
  13. BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: 13 단계, 이미지 1/2 BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: 13 단계, 이미지 2/2
    • Unscrew the Philips #1 (PH1) screw securing the green wire located at the bottom left of the metal casing.
    • Remove a second Philips #1 (PH1) screw that holds down the top of the metal casing located near the back of the projector’s lens.
  14. BenQ HT1075 Projector Blower Fan Replacement: 14 단계, 이미지 1/1
    • Remove three Philips #2 (PH2) screws that attach the metal casing to the platform.
    • Remove the metal casing by pulling it straight up.
  15. BenQ HT1075 Projector Blower Fan Replacement: 15 단계, 이미지 1/1
    • Remove the two Philips #2 (PH2) screws that hold down the black blower fan, located at top center of the circuit board.
  16. BenQ HT1075 Projector Blower Fan Replacement: 16 단계, 이미지 1/1
    • Remove the three Philips #1 (PH1) screws that attach the blower fan to the metal cover.
    • Gently remove the blower fan by pulling it directly upwards from the base.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Gabriela Remulla
회원 가입일: 09/26/17
912 평판
안내서 5개 작성하였습니다
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G1
5 회원들
안내서 5개 작성하였습니다
댓글 3개
I did the repair to clear out some dust and glass from a blown lamp. After putting it back together, I get lights most likely from no power at all. Do you think the next step would to be take back apart and make sure everything is connected correctly? I can be reached at jaspercloren@gmail.com or I will check back on here.
Thank you for all your write ups, they are very nice. I may suggest to get a closer view of the screws/bolts in case someone misplaces one.
Jasper Loren - 답글
where can we buy the replacement fan? Is there a part number for finding this part?
Rekhender Dhawan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 47
전체 시간: 9,560
