주요 콘텐츠로 건너뛰기
BenQ HT1075 Projector Bulb Replacement
필요한 것
  1. BenQ HT1075 Projector Bulb Replacement, Lamp: 1 단계, 이미지 1/1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Bulb Replacement: 2 단계, 이미지 1/1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Bulb Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Bulb Replacement: 4 단계, 이미지 1/1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Bulb Replacement, Bulb: 5 단계, 이미지 1/1
    • Using a Philips #0 (PH0) screwdriver, remove the two screws holding the metal case of the lamp housing.
  6. BenQ HT1075 Projector Bulb Replacement: 6 단계, 이미지 1/1
    • Using a 2.5mm Hex key, remove the top portion that contains the handle. This portion is also attached to the bulb housing.
  7. BenQ HT1075 Projector Bulb Replacement: 7 단계, 이미지 1/1
    • With a Philips #0 (PH0) screwdriver, remove the four screws that secure the bulb to the housing unit.
  8. BenQ HT1075 Projector Bulb Replacement: 8 단계, 이미지 1/1
    • Using a Philips#1 (PH1) screwdriver, remove the 2.5 mm Phillips #1 screw that secures the wires to the detach bulb.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gabriela Remulla
회원 가입일: 09/26/17
912 평판
안내서 5개 작성하였습니다
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G1
5 회원들
안내서 5개 작성하였습니다
댓글 3개
Hey, Thanks for sharing the steps setting a Project Bulb Replacement.
SupplyExpert - 답글
we recently replaced Ht 1075 bulb after the main bulb broke. the projector runs for 10 min and them shuts off due to overheating. previously that was not the case. what could be the issue and how we can isolate and fix the issue..
Subcon App - 답글
From my experience try replacing the main blower fan located under the motherboard
Robert Koss -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 12
전체 시간: 3,365
