주요 콘텐츠로 건너뛰기
BenQ HT1075 Projector Circuit Board Replacement
필요한 것
  1. BenQ HT1075 Projector Circuit Board Replacement, Lamp: 1 단계, 이미지 1개 중 1개
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Circuit Board Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
  6. BenQ HT1075 Projector Circuit Board Replacement, Remove the 6th screw holding the top cover: 6 단계, 이미지 1개 중 1개
    • Flip the projector and remove the 6th and last crew.
  7. BenQ HT1075 Projector Circuit Board Replacement: 7 단계, 이미지 1개 중 1개
    • Using an opening tool, remove the top cover by first loosening its top cover.
  8. BenQ HT1075 Projector Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform.
    • Gently pull the top cover from the rest of the frame.
  9. BenQ HT1075 Projector Circuit Board Replacement: 9 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Circuit Board Replacement: 9 단계, 이미지 2개 중 2개
    • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
    • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
  10. BenQ HT1075 Projector Circuit Board Replacement: 10 단계, 이미지 3개 중 1개 BenQ HT1075 Projector Circuit Board Replacement: 10 단계, 이미지 3개 중 2개 BenQ HT1075 Projector Circuit Board Replacement: 10 단계, 이미지 3개 중 3개
    • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
    • Afterwards, use a 5mm nut driver to remove the four remaining screws.
    • Use the opening tool to loosen the back cover then pull it off.
  11. BenQ HT1075 Projector Circuit Board Replacement: 11 단계, 이미지 1개 중 1개
    • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
    • Remove the metal casing.
  12. BenQ HT1075 Projector Circuit Board Replacement: 12 단계, 이미지 2개 중 1개 BenQ HT1075 Projector Circuit Board Replacement: 12 단계, 이미지 2개 중 2개
    • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
    • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gabriela Remulla
회원 가입일: 09/26/17
1,008 평판
안내서 5개를 작성함
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G1
5 회원들
안내서 9개를 작성함
2가이드 댓글
miss i need to get some information regarding this projector repair. if you can email me, sandarukbio@gmail.com
sandarukbio92 - 답글
very good instructions and pictures thank you for your detailed work
Quinn Griffith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 2,626
