주요 콘텐츠로 건너뛰기
BenQ HT1075 Projector Fan Replacement
필요한 것
  1. BenQ HT1075 Projector Fan Replacement, Lamp: 1 단계, 이미지 1/1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Fan Replacement: 2 단계, 이미지 1/1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Fan Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Fan Replacement: 4 단계, 이미지 1/1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Fan Replacement, Fan: 5 단계, 이미지 1/1
    • Turn the projector over (upside down) and remove the five 9.5 mm Philips #1 (PH1) screws that hold the projector together to its bottom cover.
  6. BenQ HT1075 Projector Fan Replacement: 6 단계, 이미지 1/1
    • Carefully, flip the projector back over to its upright position.
    • Using an opening tool, loosen then remove the top cover of the projector.
  7. BenQ HT1075 Projector Fan Replacement: 7 단계, 이미지 1/2 BenQ HT1075 Projector Fan Replacement: 7 단계, 이미지 2/2
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform .
    • Gently pull the cover from the rest of the frame.
  8. BenQ HT1075 Projector Fan Replacement: 8 단계, 이미지 1/2 BenQ HT1075 Projector Fan Replacement: 8 단계, 이미지 2/2
    • Disconnect the wire that connects the main fan to the circuit board.
    • Carefully remove the fan by pulling it directly upwards from the base.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Gabriela Remulla
회원 가입일: 09/26/17
912 평판
안내서 5개 작성하였습니다
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G1
5 회원들
안내서 5개 작성하였습니다
댓글 6개
What is the spec of the fan? I thought there were 3 fans in HT1075?
K Tao - 답글
adda ad07012db257300
Usman Amir - 답글
What the model number for Fan 1(showing errors) & Fan 3 (0 Rpm after 15 minutes).
Thank you so much
Rose - 답글
Mode number of fan is ad07012db257300 as mentioned above. Looks like eBay is best place to get these but they are all from china. The specs for the fan are hard to find elsewhere. It must be the right size, 70x70x25 12v 4200rpm 3 pin
John Ferguson -
quand on défait le couvert , il y a aussi une vis qui le tiens en haut (vers le milieu) !!! a ne pas oublier sinon on casse le couvert !
techno57 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 30
전체 시간: 6,881
