주요 콘텐츠로 건너뛰기
BenQ HT1075 Projector Lamp Replacement
필요한 것
  1. BenQ HT1075 Projector Lamp Replacement, Lamp: 1 단계, 이미지 1/1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Lamp Replacement: 2 단계, 이미지 1/1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Lamp Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Lamp Replacement: 4 단계, 이미지 1/1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Gabriela Remulla
회원 가입일: 09/26/17
912 평판
안내서 5개 작성하였습니다
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 27
전체 시간: 1,530
