주요 콘텐츠로 건너뛰기
Benchmade Griptillian Disassembly
필요한 것
  1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: 1 단계, 이미지 1개 중 1개
    • Be sure to make note of what side the belt clip is on for reassembly.
  2. Benchmade Griptillian Disassembly, Remove screws: 2 단계, 이미지 1개 중 1개
    • Use a T6 bit to remove the two screws holding the belt clip.
  3. Benchmade Griptillian Disassembly, Remove T6 Screws: 3 단계, 이미지 1개 중 1개
    • Use the T6 bit to remove the four screws holding the handle in place.
  4. Benchmade Griptillian Disassembly, Turn the knife over: 4 단계, 이미지 1개 중 1개
    • Turn the knife over and remove one T6 screw.
  5. Benchmade Griptillian Disassembly, Remove the T8 screw: 5 단계, 이미지 1개 중 1개
    • Turn the knife over and remove the T8 screw that is going through the hinge.
  6. Benchmade Griptillian Disassembly, Remove the handle: 6 단계, 이미지 1개 중 1개
    • Once you've removed the screw, you can remove the handle.
  7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: 7 단계, 이미지 1개 중 1개
    • Using the T6 bit, drive the hinge pin out of the other handle.
  8. Benchmade Griptillian Disassembly, Remove the other handle: 8 단계, 이미지 1개 중 1개
    • Once you've done this you can remove the other handle.
  9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: 9 단계, 이미지 1개 중 1개
    • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
  10. Benchmade Griptillian Disassembly, Sand both sides of copper: 10 단계, 이미지 1개 중 1개
    • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
  11. Benchmade Griptillian Disassembly, Reverse process to re assemble: 11 단계, 이미지 1개 중 1개
    • Reverse process to re assemble.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spin Modder
회원 가입일: 07/21/22
256 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 67
전체 시간: 1,073
