주요 콘텐츠로 건너뛰기
Besta Super 5000 Motherboard Replacement
필요한 것
  1. Besta Super 5000 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: 2 단계, 이미지 1/2 Besta Super 5000 Motherboard Replacement: 2 단계, 이미지 2/2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: 3 단계, 이미지 1/1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: 4 단계, 이미지 1/1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: 6 단계, 이미지 1/2 Besta Super 5000 Motherboard Replacement: 6 단계, 이미지 2/2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: 9 단계, 이미지 1/3 Besta Super 5000 Motherboard Replacement: 9 단계, 이미지 2/3 Besta Super 5000 Motherboard Replacement: 9 단계, 이미지 3/3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: 10 단계, 이미지 1/2 Besta Super 5000 Motherboard Replacement: 10 단계, 이미지 2/2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: 11 단계, 이미지 1/1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: 12 단계, 이미지 1/2 Besta Super 5000 Motherboard Replacement: 12 단계, 이미지 2/2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessie
회원 가입일: 09/30/14
370 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-5, Buehl Fall 2014 Ohio State, Team 1-5, Buehl Fall 2014 회원
OSU-BUEHL-F14S1G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 14
전체 시간: 371
