주요 콘텐츠로 건너뛰기
Bicycle Cassette Replacement
필요한 것
  1. Bicycle Cassette Replacement, Bicycle Cassette: 1 단계, 이미지 2개 중 1개 Bicycle Cassette Replacement, Bicycle Cassette: 1 단계, 이미지 2개 중 2개
    • Place your wheel on a hard surface with the cassette on your right side.
    • Wrap the chain whip clockwise around the cassette.
  2. Bicycle Cassette Replacement: 2 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 2 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the cassette lockring tool into the center of the cassette with the lever arm between 7 and 9 o'clock.
    • Holding the chain whip in place with your left hand, apply counterclockwise force on the cassette tool's lever arm.
    • Continue turning the cassette tool until the tool spins freely.
  3. Bicycle Cassette Replacement: 3 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 3 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 3 단계, 이미지 3개 중 3개
    • Lay the wheel down on a flat surface with the cassette facing upwards.
    • Loosen the cassette lockring by turning it counterclockwise.
  4. Bicycle Cassette Replacement: 4 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 4 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the cassette lockring.
    • Using both hands, lift the cassette in one piece from the freehub body.
  5. Bicycle Cassette Replacement: 5 단계, 이미지 2개 중 1개 Bicycle Cassette Replacement: 5 단계, 이미지 2개 중 2개
    • Your cassette may require a spacer to work properly with your freehub. Consult your cassette user's manual to determine your spacer needs.
    • Remove the old freehub body spacer as needed.
  6. Bicycle Cassette Replacement: 6 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 6 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the small cutout on the bottom of the new cassette.
    • Locate the small ridge on the freehub body.
    • Slide the bottom piece of the new cassette on the freehub body by matching the small cutout with the small ridge.
  7. Bicycle Cassette Replacement: 7 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 7 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 7 단계, 이미지 3개 중 3개
    • Continue placing smaller cogs on the freehub body by matching the cutouts and ridges.
    • Insert spacers as specified by the cassette user's manual.
  8. Bicycle Cassette Replacement: 8 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 8 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 8 단계, 이미지 3개 중 3개
    • For the final two cogs, locate the small cutouts and place on top of the already placed cogs by aligning with the top of small ridge on the freehub body.
    • The top two cogs will not fully slide on to the freehub body and require more attention for aligned placement.
  9. Bicycle Cassette Replacement: 9 단계, 이미지 2개 중 1개 Bicycle Cassette Replacement: 9 단계, 이미지 2개 중 2개
    • Place the cassette lockring onto the top of the final cog.
    • Start threading the lockring clockwise into the freehub by hand.
  10. Bicycle Cassette Replacement: 10 단계, 이미지 3개 중 1개 Bicycle Cassette Replacement: 10 단계, 이미지 3개 중 2개 Bicycle Cassette Replacement: 10 단계, 이미지 3개 중 3개
    • Once the lockring is partially threaded in, insert the cassette lockring tool.
    • Tighten the cassette on the freehub body by turning the lockring tool clockwise.
    • The exact torque to tighten to varies by cassette manufacturer and model. Consult the cassette user's manual.
    • After finishing tightening, check the cassette for play by pulling up on the largest cog. If excess play is present and the cassette has been tightened to specifications, a spacer is likely missing.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lars Lundqvist
회원 가입일: 04/14/25
208 평판
안내서 1개를 작성함
UC Davis, Team 1-5, Morris Spring 2025 UC Davis, Team 1-5, Morris Spring 2025 회원
UCD-MORRIS-S25S1G5
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 69
전체 시간: 473
