주요 콘텐츠로 건너뛰기
Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement
필요한 것
  1. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement, Rubber Grips on the Handlebars: 1 단계, 이미지 1/1
    • Put the straw of the air canister under the grip.
    • Pinch the end (can be done with pliers), and use the gap created to slip the straw in.
    • To separate the grip, you may use a screwdriver or another long, skinny tool allowing you to gain leverage underneath the grip.
    • While spraying air underneath the grips, pull on the grips with enough force to move them off the handlebar.
    • The air will separate the grips from the handlebars.
    • If more force is needed, you may use an air compressor with a needle attachment.
  2. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: 2 단계, 이미지 1/2 Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: 2 단계, 이미지 2/2
    • Spray the handlebar and inside the grip with your hairspray or lubricant/adhesive.
    • Slide the grips all the way on until there's no more room for the grips to slide on.
    • I use hairspray because it is both a lubricant and an adhesive. Other combos can be WD-40 and super glue.
    • If your handlebar is dirty or you want to clean it, use warm soap and water to clean it with a wash cloth.
  3. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: 3 단계, 이미지 1/1
    • Slide the new grips on.
    • Let them dry.
    • Put your brakes and shifting levers back on.
    • Finally, enjoy the new grips!
결론
In order to move or replace these grips follow these steps from top to bottom.
Phoenix Gavin-Scott Hanks Jr.
회원 가입일: 02/04/19
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 558
