주요 콘텐츠로 건너뛰기
Bicycle Handlebar Tape Replacement
필요한 것
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: 1 단계, 이미지 3개 중 1개 Bicycle Handlebar Tape Replacement, Handlebar Tape: 1 단계, 이미지 3개 중 2개 Bicycle Handlebar Tape Replacement, Handlebar Tape: 1 단계, 이미지 3개 중 3개
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: 2 단계, 이미지 3개 중 1개 Bicycle Handlebar Tape Replacement: 2 단계, 이미지 3개 중 2개 Bicycle Handlebar Tape Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: 3 단계, 이미지 3개 중 1개 Bicycle Handlebar Tape Replacement: 3 단계, 이미지 3개 중 2개 Bicycle Handlebar Tape Replacement: 3 단계, 이미지 3개 중 3개
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: 4 단계, 이미지 3개 중 1개 Bicycle Handlebar Tape Replacement: 4 단계, 이미지 3개 중 2개 Bicycle Handlebar Tape Replacement: 4 단계, 이미지 3개 중 3개
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: 5 단계, 이미지 2개 중 1개 Bicycle Handlebar Tape Replacement: 5 단계, 이미지 2개 중 2개
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: 6 단계, 이미지 2개 중 1개 Bicycle Handlebar Tape Replacement: 6 단계, 이미지 2개 중 2개
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jordan Byrnes
회원 가입일: 05/05/17
132 평판
안내서 1개를 작성함
UC Davis, Team S1-G70, Coad Spring 2017 UC Davis, Team S1-G70, Coad Spring 2017 회원
UCD-COAD-S17S1G70
3 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 609
