주요 콘텐츠로 건너뛰기
Bike Chain Installation
필요한 것
  1. Bike Chain Installation, Bike Chain Installation: 1 단계, 이미지 1/2 Bike Chain Installation, Bike Chain Installation: 1 단계, 이미지 2/2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: 2 단계, 이미지 1/2 Bike Chain Installation: 2 단계, 이미지 2/2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
aaron thielk
회원 가입일: 10/10/10
1,882 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 회원
CPSU-MANESS-F10S5G13
4 회원들
안내서 17개 작성하였습니다
댓글 2개
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 15,936
