소개
Follow these instructions to replace a damaged throttle control. Optionally, you may also replace the attached throttle control cable.
필요한 것
Use a Phillips #2 driver to remove the two screws securing the throttle control.
While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
