주요 콘텐츠로 건너뛰기
Bionaire Mini Tower Fan Blade Replacement
필요한 것
  1. Bionaire Mini Tower Fan Blade Replacement, Blades: 1 단계, 이미지 1/2 Bionaire Mini Tower Fan Blade Replacement, Blades: 1 단계, 이미지 2/2
    • There are 6 screws holding the entire fan together, which need to be removed to access the internals of the fan.
  2. Bionaire Mini Tower Fan Blade Replacement: 2 단계, 이미지 1/1
    • Once the screws are all off, the fan can be pulled apart with a little bit of force. However, not too much force is required.
  3. Bionaire Mini Tower Fan Blade Replacement: 3 단계, 이미지 1/3 Bionaire Mini Tower Fan Blade Replacement: 3 단계, 이미지 2/3 Bionaire Mini Tower Fan Blade Replacement: 3 단계, 이미지 3/3
    • Once you have the fan apart, in order to get more maneuverability, the wire attached to the motor needs to be loosened. This can be done by removing the two screws highlighted in red.
  4. Bionaire Mini Tower Fan Blade Replacement: 4 단계, 이미지 1/2 Bionaire Mini Tower Fan Blade Replacement: 4 단계, 이미지 2/2
    • To get more maneuverability, remove the button panel. This can be done by removing the 2 screws on either side of the panel in order to fully remove it.
  5. Bionaire Mini Tower Fan Blade Replacement: 5 단계, 이미지 1/2 Bionaire Mini Tower Fan Blade Replacement: 5 단계, 이미지 2/2
    • Carefully remove the panel by pulling on it. It should fall out easily and separate completely from its housing.
  6. Bionaire Mini Tower Fan Blade Replacement: 6 단계, 이미지 1/2 Bionaire Mini Tower Fan Blade Replacement: 6 단계, 이미지 2/2
    • The bolt that you need to remove is inside of the pre-installed fan blades. With your pliers, grab a hold of the nut and twist to the RIGHT. This will allow you to remove the fan blades.
  7. Bionaire Mini Tower Fan Blade Replacement: 7 단계, 이미지 1/3 Bionaire Mini Tower Fan Blade Replacement: 7 단계, 이미지 2/3 Bionaire Mini Tower Fan Blade Replacement: 7 단계, 이미지 3/3
    • In order to install the new blades, there are two pieces that you have to match up. The blades and pole both have a flat side that you have to match up in order for the blades to stay on.
    • Make sure when you install the blades, it blows air when it rotates in a counterclockwise fashion.
  8. Bionaire Mini Tower Fan Blade Replacement: 8 단계, 이미지 1/1
    • Tighten the bolt to the left and you have successfully installed your new fan blades.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kyle Taggard
회원 가입일: 09/29/15
218 평판
안내서 1개 작성함
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 회원
CPSU-GREEN-F15S14G4
5 회원들
안내서 16개 작성하였습니다
댓글 한 개
Thank you the instructions were spot on
Jason Mendez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 40
전체 시간: 3,739
