주요 콘텐츠로 건너뛰기
Bissell Air180 Control Buttons Replacement
필요한 것
  1. Bissell Air180 Control Buttons Replacement, Air Filter: 1 단계, 이미지 2개 중 1개 Bissell Air180 Control Buttons Replacement, Air Filter: 1 단계, 이미지 2개 중 2개
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Control Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Control Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Control Buttons Replacement, Power Supply: 4 단계, 이미지 1개 중 1개
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Control Buttons Replacement: 5 단계, 이미지 3개 중 1개 Bissell Air180 Control Buttons Replacement: 5 단계, 이미지 3개 중 2개 Bissell Air180 Control Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Control Buttons Replacement, Control Buttons: 6 단계, 이미지 3개 중 1개 Bissell Air180 Control Buttons Replacement, Control Buttons: 6 단계, 이미지 3개 중 2개 Bissell Air180 Control Buttons Replacement, Control Buttons: 6 단계, 이미지 3개 중 3개
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Control Buttons Replacement: 7 단계, 이미지 2개 중 1개 Bissell Air180 Control Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Control Buttons Replacement: 8 단계, 이미지 2개 중 1개 Bissell Air180 Control Buttons Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
결론
작성자
2다른 기여자 명과 함께
Aleah Ramos
회원 가입일: 10/26/22
533 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-4, Botvin Fall 2022 UMass Dartmouth, Team 3-4, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 165
