소개
This guide will help you take apart the handheld vacuum using the most appropriate tools to replace the battery.
필요한 것
다른 13명이 해당 안내서를 완성하였습니다.
댓글 23개
Do you have the specs for the replacement battery? Model number? Any suggested sources?
Don Abrams - 답글
There is no replacement battery. The vacuum does have a two year warranty. If you call Bissell, they will replace the vacuum.
They will replace it with a refurbished one. In 6 months the same thing will happen and they don't warranty the replacement.
elarvick -
So why show how to take it apart if I can't replace the battery??
