주요 콘텐츠로 건너뛰기
Bissell Pet Hair Eraser Motorized Brush Belt Replacement
필요한 것
  1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: 1 단계, 이미지 1/2 Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: 1 단계, 이미지 2/2
    • Turn power OFF.
    • Detach motorized brush from the vacuum.
  2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 2 단계, 이미지 1/2 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 2 단계, 이미지 2/2
    • Use a spudger or a coin to turn the circular lock clockwise to unlock the brush roll.
    • Remove the lock cover.
  3. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 3 단계, 이미지 1/1
    • Lift brush out of the enclosure.
  4. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 4 단계, 이미지 1/3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 4 단계, 이미지 2/3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 4 단계, 이미지 3/3
    • Remove the four 13.0 mm Phillips #0 screws and remove the green cover.
  5. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 5 단계, 이미지 1/1
    • Take out the motor assembly.
  6. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush Belt: 6 단계, 이미지 1/1
    • Take the belt off the gear by using a spudger.
  7. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 7 단계, 이미지 1/3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 7 단계, 이미지 2/3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: 7 단계, 이미지 3/3
    • Grab the new belt and slide it on to the two gears.
    • Place the motor assembly back into the motorized brush enclosure.
결론
To reassemble your device, follow the motorized brush disassembly instructions in reverse order.
Roman Dyagilev
회원 가입일: 11/11/17
217 평판
안내서 2개 작성하였습니다
IUPUI, Team S4-G4, Wilson Fall 2017 IUPUI, Team S4-G4, Wilson Fall 2017 회원
IUPUI-WILSON-F17S4G4
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 419
