주요 콘텐츠로 건너뛰기
Bissell Powerglide Cordless Debris Canister Funnel Replacement
필요한 것
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: 1 단계, 이미지 1/3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: 1 단계, 이미지 2/3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: 1 단계, 이미지 3/3
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 2 단계, 이미지 1/1
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: 3 단계, 이미지 1/1
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 4 단계, 이미지 1/1
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 5 단계, 이미지 1/2 Bissell Powerglide Cordless Debris Canister Funnel Replacement: 5 단계, 이미지 2/2
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 6 단계, 이미지 1/1
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
결론
Joseph Adam Johnson
회원 가입일: 02/05/18
511 평판
안내서 5개 작성하였습니다
Cal Poly, Team S21-G2, Banghart Winter 2018 Cal Poly, Team S21-G2, Banghart Winter 2018 회원
CPSU-BANGHART-W18S21G2
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 205
