주요 콘텐츠로 건너뛰기
Bissell Powerglide Cordless Release Button Replacement
필요한 것
  1. Bissell Powerglide Cordless Release Button Replacement, Release Button: 1 단계, 이미지 1/2 Bissell Powerglide Cordless Release Button Replacement, Release Button: 1 단계, 이미지 2/2
    • Press the release button while pulling up on the head of the vacuum to remove the head.
  2. Bissell Powerglide Cordless Release Button Replacement: 2 단계, 이미지 1/1
    • Using a Phillips head screwdriver, unscrew the four screws holding the panel to the shaft of the vacuum.
  3. Bissell Powerglide Cordless Release Button Replacement: 3 단계, 이미지 1/2 Bissell Powerglide Cordless Release Button Replacement: 3 단계, 이미지 2/2
    • Pry the panel up using a spudger and pull up firmly just enough to see the clips of wire on the sides.
  4. Bissell Powerglide Cordless Release Button Replacement: 4 단계, 이미지 1/1
    • Remove the wire clips on both sides of the shaft.
  5. Bissell Powerglide Cordless Release Button Replacement: 5 단계, 이미지 1/1
    • Pull the top piece out of the shaft.
  6. Bissell Powerglide Cordless Release Button Replacement: 6 단계, 이미지 1/3 Bissell Powerglide Cordless Release Button Replacement: 6 단계, 이미지 2/3 Bissell Powerglide Cordless Release Button Replacement: 6 단계, 이미지 3/3
    • Pinch the two pairs of plastic catches (circled in the picture) to release the button.
결론
Khanh Fleshman
회원 가입일: 01/28/18
133 평판
안내서 1개 작성함
CPSU-BANGHART-W18S21G2 CPSU-BANGHART-W18S21G2 회원
Community
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 157
