주요 콘텐츠로 건너뛰기
Bissell SmartClean 1605 Filter Replacement
필요한 것
  1. Bissell SmartClean 1605 Filter Replacement, Filter: 1 단계, 이미지 1/1
    • Position the SmartClean so that the Bissell logo is facing towards you backwards.
  2. Bissell SmartClean 1605 Filter Replacement: 2 단계, 이미지 1/3 Bissell SmartClean 1605 Filter Replacement: 2 단계, 이미지 2/3 Bissell SmartClean 1605 Filter Replacement: 2 단계, 이미지 3/3
    • Remember to press down till the cover clicks when reassembling.
    • Press down on the cover with the diamonds and lift up.
  3. Bissell SmartClean 1605 Filter Replacement: 3 단계, 이미지 1/3 Bissell SmartClean 1605 Filter Replacement: 3 단계, 이미지 2/3 Bissell SmartClean 1605 Filter Replacement: 3 단계, 이미지 3/3
    • Flip the handle away from the cover.
    • Lift the handle up to open up the dust bin.
  4. Bissell SmartClean 1605 Filter Replacement: 4 단계, 이미지 1/3 Bissell SmartClean 1605 Filter Replacement: 4 단계, 이미지 2/3 Bissell SmartClean 1605 Filter Replacement: 4 단계, 이미지 3/3
    • Use your finger to hook the filter through the opening near the center of the filter.
    • Gently yank the filter out with your fingers.
결론
Johnny
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Cal Poly, Team S7-G4, Banghart Fall 2017 Cal Poly, Team S7-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 297
