주요 콘텐츠로 건너뛰기
Bissell SmartClean 1605 Front Cover Replacement
필요한 것
  1. Bissell SmartClean 1605 Front Cover Replacement, Front Cover: 1 단계, 이미지 1/1
    • Power off your device
  2. Bissell SmartClean 1605 Front Cover Replacement: 2 단계, 이미지 1/1
    • Flip your device and unscrew the marked screws using a phillips screwdriver.
  3. Bissell SmartClean 1605 Front Cover Replacement: 3 단계, 이미지 1/3 Bissell SmartClean 1605 Front Cover Replacement: 3 단계, 이미지 2/3 Bissell SmartClean 1605 Front Cover Replacement: 3 단계, 이미지 3/3
    • Gently pry off the top half of the front cover
    • Remove the wires from the socket.
    • Don't pull the wires too hard, they can become disconnected from the plastic plug.
  4. Bissell SmartClean 1605 Front Cover Replacement: 4 단계, 이미지 1/3 Bissell SmartClean 1605 Front Cover Replacement: 4 단계, 이미지 2/3 Bissell SmartClean 1605 Front Cover Replacement: 4 단계, 이미지 3/3
    • Once the top cover is removed, pry off the bottom casing.
결론
Michael Derrenbacher
회원 가입일: 09/26/17
104 평판
안내서 1개 작성함
Cal Poly, Team S7-G4, Banghart Fall 2017 Cal Poly, Team S7-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 217
