주요 콘텐츠로 건너뛰기
Bissell SmartClean 1605 Roller Brush Replacement
필요한 것
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: 1 단계, 이미지 1/1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: 2 단계, 이미지 1/1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: 3 단계, 이미지 1/3 Bissell SmartClean 1605 Roller Brush Replacement: 3 단계, 이미지 2/3 Bissell SmartClean 1605 Roller Brush Replacement: 3 단계, 이미지 3/3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: 4 단계, 이미지 1/2 Bissell SmartClean 1605 Roller Brush Replacement: 4 단계, 이미지 2/2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
결론
Austin Maranville
회원 가입일: 09/26/17
117 평판
안내서 1개 작성함
Cal Poly, Team S7-G4, Banghart Fall 2017 Cal Poly, Team S7-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G4
5 회원들
안내서 5개 작성하였습니다
댓글 13개
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - 답글
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - 답글
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - 답글
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 1,048
