주요 콘텐츠로 건너뛰기
Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement
  1. Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement, Dirt Bin: 1 단계, 이미지 1개 중 1개
    • make sure Bissell Spinwave is disconnected from power source
  2. Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement: 2 단계, 이미지 1개 중 1개
    • press the white button on top of the Dirt Bin
  3. Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement: 3 단계, 이미지 1개 중 1개
    • While holding the white button on top of the dirt bin, remove the dirt bin from the Bissell Spinwave pet.
  4. Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement, Brush Gaurd: 4 단계, 이미지 2개 중 1개 Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement, Brush Gaurd: 4 단계, 이미지 2개 중 2개
    • flip over Bissell Spinwave pet.
    • Bush down on both grey buttons.
  5. Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up brush guard while squeezing
  6. Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement, Brush Roll: 6 단계, 이미지 2개 중 1개 Bissell SpinWave Pet Robot Vacuum Brush Roll Replacement, Brush Roll: 6 단계, 이미지 2개 중 2개
    • Grab the ends of the brush roll and pull out.
    • You may have to wiggle it a bit and use some force.
    • To insert the new brush roll, align the square and circle slots on the sides of the brush with the slots inside of the brush roll placement within the vacuum.
결론
To reassemble your device, follow these steps in reverse order.
Make sure that each step that was done is properly working and put on correctly before reassembling.
작성자
4다른 기여자 명과 함께
Dube Aniagu
회원 가입일: 10/22/24
403 평판
안내서 3개를 작성함
UMass Dartmouth, Team 3-5, Santin Fall 2024 UMass Dartmouth, Team 3-5, Santin Fall 2024 회원
UMASSD-SANTIN-F24S3G5
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 26
전체 시간: 64
