주요 콘텐츠로 건너뛰기
Bissell SpotBot Pet Control Panel Replacement
필요한 것
  1. Bissell SpotBot Pet Control Panel Replacement, Control Panel: 1 단계, 이미지 1/1
    • Start here.
  2. Bissell SpotBot Pet Control Panel Replacement: 2 단계, 이미지 1/1
    • Remove the container on the right side of the vacuum.
  3. Bissell SpotBot Pet Control Panel Replacement: 3 단계, 이미지 1/2 Bissell SpotBot Pet Control Panel Replacement: 3 단계, 이미지 2/2
    • Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
  4. Bissell SpotBot Pet Control Panel Replacement: 4 단계, 이미지 1/1
    • Remove the left container of the vacuum.
  5. Bissell SpotBot Pet Control Panel Replacement: 5 단계, 이미지 1/1
    • Remove the four screws on the top of the device.
  6. Bissell SpotBot Pet Control Panel Replacement: 6 단계, 이미지 1/1
    • Lift the top of the device off once the screws are removed.
  7. Bissell SpotBot Pet Control Panel Replacement: 7 단계, 이미지 1/1
    • Unplug the ribbon cable from the motherboard.
  8. Bissell SpotBot Pet Control Panel Replacement: 8 단계, 이미지 1/1
    • Separate the top piece and flip it upside down.
  9. Bissell SpotBot Pet Control Panel Replacement: 9 단계, 이미지 1/2 Bissell SpotBot Pet Control Panel Replacement: 9 단계, 이미지 2/2
    • Remove the screws holding the motherboard in place.
  10. Bissell SpotBot Pet Control Panel Replacement: 10 단계, 이미지 1/2 Bissell SpotBot Pet Control Panel Replacement: 10 단계, 이미지 2/2
    • Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Anthony Bonvino
회원 가입일: 09/26/17
437 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G3
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where can I buy the part?
Sue Loberger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 530
