소개
Is the water tank on your Bissell SpotClean ProHeat 5207U leaking? It could be because of a failing float gasket. Follow this guide to replace the float gasket on your Bissell SpotClean ProHeat 5207U .
필요한 것
Position the device so that you can see the text at the bottom saying "SpotClean ProHeat."
Remove the dirty water tank located to the right.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
