주요 콘텐츠로 건너뛰기
Bissell SpotClean ProHeat 5207U Hose Replacement
필요한 것
  1. Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: 1 단계, 이미지 1/2 Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: 1 단계, 이미지 2/2
    • Ensure Bissell SpotClean ProHeat is unplugged
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
    • Remove the dirty water tank and the clean water tank that are located on either side.
  2. Bissell SpotClean ProHeat 5207U Hose Replacement: 2 단계, 이미지 1/3 Bissell SpotClean ProHeat 5207U Hose Replacement: 2 단계, 이미지 2/3 Bissell SpotClean ProHeat 5207U Hose Replacement: 2 단계, 이미지 3/3
    • Turn the device so that the bottom is facing up.
    • Remove the marked 19.7 mm screws using the Phillips #00 screwdriver to remove the plastic covering.
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three screws located under the plastic cover that was previously removed.
  3. Bissell SpotClean ProHeat 5207U Hose Replacement: 3 단계, 이미지 1/2 Bissell SpotClean ProHeat 5207U Hose Replacement: 3 단계, 이미지 2/2
    • Remove the plastic lip that was previously held by the screws.
    • Remove the 17.2 mm screws using the Phillips #00 Screwdriver to gain access to the water pump.
  4. Bissell SpotClean ProHeat 5207U Hose Replacement: 4 단계, 이미지 1/2 Bissell SpotClean ProHeat 5207U Hose Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to to squeeze together the prongs of the hose clamp.
    • With the clamp squeezed, pull the hose from the pump.
    • We found it easier to pull the clamp up the hose then pull the hose from the pump.
  5. Bissell SpotClean ProHeat 5207U Hose Replacement: 5 단계, 이미지 1/1
    • Pull the hose from the opposite end of the pump until it is fully removed.
    • Replace the previous non-working hose with a new working hose.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zachary Chandler
회원 가입일: 09/13/23
369 평판
안내서 2개 작성하였습니다
University of North Texas, Team 6-4, Kilpatrick Fall 2023 University of North Texas, Team 6-4, Kilpatrick Fall 2023 회원
UNT-KILPATRICK-F23S6G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 115
전체 시간: 567
