소개
Is your Bissell SpotClean ProHeat 5207U not spraying water? It could be because of a failing water pump. Follow this guide to replace the water pump for your Bissell SpotClean ProHeat 5207U.
필요한 것
Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
