소개
If any issues are arising inside your Bissell Zing 2156A, or you simply want to replace the casing, this guide will assist in taking it apart.
The casing is a extruded plastic shell, with other smaller plastic bits coming out of it. The casing is held in place by screws and small "snap-fit" fasteners. This guide starts with the removal of the rear wheel.
Overall, this assembly is safe to disassemble and reassemble.
필요한 것
Remove the dust tank, so the vacuum can lie upside down easily.
Press the grey button while pulling up.
다른 한 분이 해당 안내서를 완성하였습니다.
