주요 콘텐츠로 건너뛰기
Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement
필요한 것
  1. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement, Line: 1 단계, 이미지 1/1
    • To prepare a new line for your weed whacker, use your utility scissors and cut a piece of line between 30 cm and 50 cm long.
  2. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 2 단계, 이미지 1/1
    • Press the buttons on the opposite sides of the trimmer cover and lift it off the head of the trimmer.
  3. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 3 단계, 이미지 1/2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 3 단계, 이미지 2/2
    • Remove the spool from the trimmer head.
    • Be careful when removing the spool as the line is still being fed through the access hole.
  4. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 4 단계, 이미지 1/2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 4 단계, 이미지 2/2
    • Remove any remaining pieces of old line by sliding it out of the space it sits in.
    • Insert the new line into the opening.
  5. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 5 단계, 이미지 1/1
    • Wrap your line around the spool and make sure you leave 10 cm of the line loose.
    • There are arrows on the spool indicating which direction to wrap the line.
  6. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 6 단계, 이미지 1/1
    • Insert the end of the line into the metal hole.
    • Feed about 10 cm of line through the hole.
  7. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 7 단계, 이미지 1/2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 7 단계, 이미지 2/2
    • Place spool back in place and snap it into place.
    • Place the cover back on the head of the weed whacker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Camille Guzman
회원 가입일: 09/19/22
145 평판
안내서 1개 작성함
York University, Team A-5, Morris Fall 2022 York University, Team A-5, Morris Fall 2022 회원
YORK-MORRIS-F22SAG5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 101
전체 시간: 1,164
