주요 콘텐츠로 건너뛰기
Black and Decker BDEDMT Directional Switch Replacement
필요한 것
  1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: 1 단계, 이미지 1/2 Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: 1 단계, 이미지 2/2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 2 단계, 이미지 1/3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 2 단계, 이미지 2/3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 2 단계, 이미지 3/3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: 3 단계, 이미지 1/2 Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: 3 단계, 이미지 2/2
    • Gently pull up on the trigger module.
    • Be sure to not loosen or disturb any wiring.
  4. Black and Decker BDEDMT Directional Switch Replacement: 4 단계, 이미지 1/2 Black and Decker BDEDMT Directional Switch Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • With the trigger module out of the way you will then remove the metal piece that is located behind the directional switch and has the spring attached to it.
    • Do this by simply pulling up on the metal with your fingers or your tweezers.
    • Make sure to not loosen or remove the black trigger stopper.
  5. Black and Decker BDEDMT Directional Switch Replacement: 5 단계, 이미지 1/2 Black and Decker BDEDMT Directional Switch Replacement: 5 단계, 이미지 2/2
    • The black directional switch can now be freely removed.
결론
Tyler Yurina
회원 가입일: 02/01/16
419 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 회원
UWT-ROSE-W16S1G2
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 368
